Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and
www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
        Utopia Ballista LE
        Intel Core i7-3770K (3.5GHz/4.8GHz)
        Computer Planet Nvidia Battlebox
        Fierce PC Prodigy GT (Windows 8)
        Intel Core i7-2600K (3.4GHz/5GHz)
        Intel Core i7-4770K (3.5GHz/4.7GHz)
        Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
        Intel Core i5-4670K (3.4GHz/4.6GHz)
        AMD FX-8350 (4GHz/4.8GHz)
Score, higher is better
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
        Utopia Ballista LE (Windows 7)
          1000
          1500
          2000
          2500
          3000
Cinebench R11.5 and R1564-bit
Download from: www.maxon.net
Cinebench uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench  can be viewed as a real-world benchmark. We've included results for R11.5 and for the new R15 and will be adding more results to the latter as we benchmark new systems.
        Core i7-4960X Extreme Edition (4.6GHz)
        Utopia Ballista LE
